Search Drop-down box on Toolbar
stanmkatz
Post by stanmkatz »
On the default toolbar with the evaluation Version 3.97n, the drop-down box with the search text is places over the buttons to it's left, and there is an unused space to the right of it - it looks as if it is positioned just over 2.5 buttons to the left of where it should be.
When installing this version did you run the full installer :?:
Could you send me a screen shot using the e-mail address from below :?:
It sounds like a similar configuration bug that I have seend before.
If it is that bug it should be possible to fix as follows:
1) Double click on the toolbar to bring up the configuration
2) Find the search combo box in the list on the right
3) Move the item up and then move the item back down
4) Apply the changes
5) The toolbar will now look broken
5) Restart the Zeus editor and both issue should now be fixed.
Let me know if that helps.
stanmkatz
Post by stanmkatz »
Thanks - I emailed you the screenshot, but your fix did work so all is going well.
Just in case I did not mention it, I did run the full installer
This issue should be fixed in the Zeus download found here: http://www.zeusedit.com/zforum/viewforum.php?f=6
