Informix/4gl/genero code folding bug
gwgs
Post by gwgs »
IF abc = def THEN
ELSE
END IF
Using the above code, fold ELSE, then fold IF, result will be just one line:
IF abc = def THEN ...
If you fold the IF and then the ELSE you get:
ELSE ... END IF
only occurs in Informix. In python and powerflex it folds correctly.
Zeus 3.97n
Win 7
Grant
Hi Grant,
This is by design. The else is a fold point just like the if and end if.
But that one is a bug. I have seen this before and from what I recall it is a tough one to fix :(
