I was trying to use Zeus to edit/view a log file, which is big. It has about 114000 lines, and size of it is about 5.69MB.
The problem I was seeing is, the vertical scroll bar did not work well. I tried to use scroll bar to access the end of the file. But that did not work. After moving the vertical scroll bar to the very bottom of the editor, and releasing the left mouse button, the scroll bar went back to the middle of the track, and I was seeing the content in the middle of the file. Tried again, the same thing happened. By using the scroll bar, I could not reach the end of the file.
I am using version 3.97m.
Jeff
problem of edit big text file
Hi Jeff,
Thanks for taking the time to post this bug report.
The good news is I have managed to replicate the issue at this end
Having replicated the issue it should be easy enough to fix.
Look out for a new beta release shortly.
Hi Jeff,
This issue should be fixed in latest beta found here: http://www.zeusedit.com/z300/zeus-beta-patch.zip
Thanks once again for the bug report.
