-- Name: Matching Brace Select
-- Language: Lua Macro
-- Description: This Lua macro will try to find the nearest brace character
-- and then select the region from the that brace character to
-- the matching brace character.
function find_brace()
found = 0
char_current = get_char_at()
char_previous = '\0'
if get_cursor_pos() > 1 then
char_previous = get_char_at(get_line_pos(),get_cursor_pos()-1)
-- position the cursor for the brace match that follows
if char_current == string.byte('(') or
char_current == string.byte('<') or
char_current == string.byte('[') or
char_current == string.byte('{') then
found = 1
elseif
char_current == string.byte(')') or
char_current == string.byte('>') or
char_current == string.byte(']') or
char_current == string.byte('}') then
found = 1
elseif
char_previous == string.byte(')') or
char_previous == string.byte('>') or
char_previous == string.byte(']') or
char_previous == string.byte('}') then
found = 1
if found == 0 then
search_options_save()
REVERSE = 1
set_search_option("UseCase" , 0)
set_search_option("WholeWord" , 1)
set_search_option("RegExpress", 0)
set_find_text("{")
if SearchPrevious() == 1 then
MoveLineRight()
found = 1
if found == 0 then
set_find_text("{")
MoveLineRight()
found = 1
if found == 0 then
set_find_text("<")
MoveLineRight()
found = 1
if found == 0 then
set_find_text("(")
MoveLineRight()
found = 1
search_options_restore()
if document > 0 then
-- save the char_current cursor details
cursor_save()
-- look for the nearest brace
find_brace()
MoveLineRight()
elseif
MoveLineLeft()
-- turn on marking
MarkBlockSet()
-- look for a matching brace
if BraceMatch() == 1 then
-- ignore the saved cursor details
cursor_ignore()
-- see where we ended up
char_previous = get_char_at(get_line_pos(), get_cursor_pos() - 1)
-- position the cursor inside the brace chracters found
MoveLineRight()
elseif
MoveLineLeft()
-- marking is done
MarkBlockReset()
-- restore the cursor as no matching brace was found
cursor_restore()
-- remove the marking
MarkHide()
message("This macro only works for document files.")
