Hi, Jussi
Some years ago, you sent me the source code for the COBOL tag analysis module used with ctags, which I modified a bit and sent back to you. I'm back to looking at some legacy COBOL code, and it looks like you have developed this a bit farther. Also, there are a few things I'd like to experiment with. Could you send me the source code used to build the ctags (xtags) program? Which version of the Exuberant Ctags program is your current base? I can download the source if you prefer, but I'd like to have the version of cobol.c (at a minimum) that you are using, or any other of the language modules that you've modified. If my experiments look like they are an improvement, I'll be happy to send you back the source.
TIA
Bill Diener
COBOL Tags
Hi Bill,
But the zip file above should contain all the files needed. Let me know if it does not.
The changes should be marked by the initials JAJ.
I would have done that around the time you first raised the issue.it looks like you have developed this a bit farther.
The source code is found here: http://www.zeusedit.com/z300/ctags_src.zipAlso, there are a few things I'd like to experiment with. Could you send me the source code used to build the ctags (xtags) program?
I think it was the 5.80 release.Which version of the Exuberant Ctags program is your current base?
From what I recall I did have to add a few breaking ctags changes for COBOL so it might be difficult to use the official ctags source codeI can download the source if you prefer
I would have made changes for C/C++, C#, COBOL, D1, Forth, Fortran, SQL and Go.but I'd like to have the version of cobol.c (at a minimum) that you are using, or any other of the language modules that you've modified.
I'll be more than happy to add your changes back into the xtags at this endI'll be happy to send you back the source.
