Zeus appears to use MS Sans Serif or a similar font in its dialogs. This bitmap font is unattractive and hard to read, and it makes the software look old and out of date. Really, very few programs use MS Sans Serif any more.
It should be straightforward to change it to Microsoft Sans Serif, a matching TrueType font. Or you could use Tahoma or the MS Shell Dlg [2] logical font. The result would be much better looking and easier to read dialogs.
Thanks!
edit: The tab titles also use a bitmap font that would look much better as a TrueType font. (They could also use a bit larger font - that really is small!)
Also, I hope my comment about the bitmap font looking "old and out of date" did not come across as snarky or critical - I didn't mean it that way. I'm not suggesting chasing the latest UI trends, but a good TrueType font really is a lot easier to read. Thanks!
Please use TrueType dialog font insted of bitmap font
Yes indeed it does. Well spottedZeus appears to use MS Sans Serif or a similar font in its dialogs.
// From the Dialog Resoure code
FONT 8, "MS Sans Serif", 0, 0, 0x0This a very good point that I had never considered. Thanks.This bitmap font is unattractive and hard to read, and it makes the software look old and out of date. Really, very few programs use MS Sans Serif any more.
I'll look at this as well.The tab titles also use a bitmap font that would look much better as a TrueType font. (They could also use a bit larger font - that really is small!)
No offense taken.Also, I hope my comment about the bitmap font looking "old and out of date" did not come across as snarky or critical - I didn't mean it that way.
In fact your comments are very accurate. The font details in Zeus would have been added to the dialog resourse many years ago and never change since. So I think it is about time they got updated.
This will be fixed shortly.
This line did give me a chuckle. I think Zeus has always dressed badly when compared to other trendy applicationsI'm not suggesting chasing the latest UI trends
Thanks again for your feedback.
This dialog font issue has been fixed in the latest patch found here: http://www.zeusedit.com/z300/zeus-beta-patch.zip
All the dialogs now use the MS Shell Dlg font.
The file tab control now also uses a true type font.
I still have to look at making the tab control font larger.
These other font issue are now fixed in the latest patch found here: http://www.zeusedit.com/z300/zeus-beta-patch.zip
I also fixed the search drop down combo box found in the toolbar.
