The latest Zeus release adds support for gocode autocomplete. Here is a link to a video showing the autocomplete in action.
The latest Zeus release can be found here: http://www.zeusedit.com/download.html
This release includes the macros you need to work with the gocode tool.
Macros Included in this Release
go_code.py
go_intellisense.py
go_intellisense_dot.lua
go_intellisense_brace.lua
Macro Setup
1) Use the Options, Editor Options menu.
2) In the Keyboard Mapping section edit the active keyboard and bind the go_intellisense_dot.lua to the '.' (i.e. the period) keyboard character.
3) In the Keyboard Mapping section edit the active keyboard and bind the go_intellisense_brace.lua to the '(' (i.e. the brace) keyboard character.
4) Bind the go_intellisense.py macro to some other keyboard key combination (i.e. Ctrl+Space etc).
How They Work
The go_intellisense.py macro does general autocomplete and can be used for example to autocomplete somthing like this:
fmt.Pr|
^cursor here and press the Ctrl+Space autocomplete keyboard keys (i.e. step 4)
math.
^fires on the '.' key press
math.Abs(
^fires on the '(' key press
Setting up the Go compiler
Go Auto-formatting on Save (using goimports)
