For example this:
    "Hello World"Code: Select all
    System.out.println("Hello World");Code: Select all
-- Simple Lua Macro
-- Take the current word or marked area and wrap it in a print
-- statement.
-- For example highlight "Hello World" run the macro and the text
-- will be convert into this:
--   System.out.println("Hello World")
-- This macro can be bound to any key combination or to the menu.
    local word = ""
    if is_marked() then
        -- get the marked area
        word = macro_tag("$M")
        -- delete the marked text
        MarkDelete()
        -- get the current word or marked area
        word = macro_tag("$WordEx")
        if string.len(word) > 0 then
            -- delete the current word
            WordDelete()
        -- write out the print line call
        print("System.out.println(" .. word .. ");")
        message("No marked text was found and the cursor is not over a word!")
