List of file types in "File > open" using Windo
Zoe
Post by Zoe »
I have just switched over to Windows 7. When I go to File > Open , it seems that the default file type is *.*.
When I used Windows XP, it used to filter the list to the one that I had last used.
I couldn't remember whether I had to set this up so I did a search and found this:
http://www.zeusedit.com/zforum/viewtopi ... =file+open
from which it appears that zeus should automatically filter the files to the on that is currently open.
But this doesn't appear to be happening in Windows 7. Am I doing something wrong or is it a Windows 7 issue?
Zoe
Post by Zoe »
I fixed it.
For anyone reading this, I fixed it by going to Options > Editor Options and in the General tab, clicking on "Enable File type Filtering"
