Zeus Auto-Complete for the Corona SDK
Initial Setup
Find below a file that provides Zeus auto-complete for the Corona SDK.
Note: The directions below assume you are running Windows XP (see below if this is not the case)
To use this file do the following:
  1. Create a new workspace called Lua in the following folder location:
    c:\Program Files\Zeus\zTags\
  2. Remove the Header and Resource folders.
  3. Add this file (which should already exist) to the Source folder of that workspace:
    c:\Program Files\Zeus\zTags\Templates\Lua.js
  4. Replace the contents of that file with the code found below.
Now create a new Lua file and type in some code like this:
display.
The intellisense for the display object should now be shown as expected.
Note: If you are running on Windows 7 then the location of these files will be different.
To find the corrent location just use the Macro, Load menu and in the resulting dialog move up one folder level to help the correct zTags folder location.
Setup Syntax Highlighting
To get the Zeus syntax highlighter to recognise these keywords do the following:
  1. Use the Options, Document Types menu to edit the Lua Document Type.
  2. Select the Keywords panel and hit the Tags Syntax Highlighting button.
  3. Tick the Classes, Functions, Methods, and Variables check boxes.
  4. Apply the changes.
  5. Select the Coloring panel and in the Category section adjust the Tag - * color values to suit.
  6. Apply the changes.
Zeus - Corona SDK API Reference
//  Zeus - Corona SDK API Reference
//  Created using this web page:
//     http://developer.anscamobile.com/reference
assert();
error();
getfenv();
getmetatable();
ipairs();
next();
pairs();
pcall();
print();
rawequal();
rawget();
rawset();
select();
setfenv();
setmetatable();
tonumber();
tostring();
type();
unpack();
class coroutine
    create(f);
    resume(co [, val1, ···]);
    running();
    status(co);
    wrap(f);
    yield(···);
class debug
    debug();
    getfenv(o);
    gethook([thread]);
    getinfo([thread,] function [, what]);
    getlocal([thread,] level, local);
    getmetatable(object);
    getregistry();
    getupvalue(func, up);
    setfenv(object, table);
    sethook([thread,] hook, mask [, count]);
    setlocal([thread,] level, local, value);
    setmetatable(object, table);
    setupvalue(func, up, value);
    traceback([thread,] [message] [, level]);
class ads
    hide();
    init();
    show();
class analytics
    init();
    logEvent();
class easing
    inExpo();
    inOutExpo();
    inOutQuad();
    inQuad();
    linear();
    outExpo();
    outQuad();
class movieclips
    newAnim();
    nextFrame();
    play();
    previousFrame();
    reverse();
    setDrag();
    setLabels();
    stop();
    stopAtFrame();
class transitions
    cancel();
    dissolve();
    from();
    to();
class table
    concat(table [, sep [, i [, j]]]);
    copy(table);
    indexOf();
    insert(table, [pos,] value);
    maxn(table);
    remove(table [, pos]);
    sort(table [, comp]);
class audio
    dispose();
    fade();
    fadeOut();
    findFreeChannel();
    freeChannels;
    getDuration();
    getMaxVolume();
    getMinVolume();
    getVolume();
    isChannelActive();
    isChannelPaused();
    isChannelPlaying();
    loadSound();
    loadStream();
    pause();
    play();
    reserveChannels();
    reservedChannels;
    resume();
    rewind();
    seek();
    setMaxVolume();
    setMinVolume();
    setVolume();
    stop();
    stopWithDelay();
    totalChannels;
    unreservedFreeChannels;
    unreservedUsedChannels;
    usedChannels;
class credits
    init();
    requestUpdate();
    showOffers();
class crypto
    digest();
    hmac();
    md4
    md5
    sha1
    sha224
    sha256
    sha384
    sha512
class display
    display.remove();
    addEventListener;
    contentToLocal();
    dispatchEvent();
    getParent();; // **old**
    localToContent();
    removeEventListener();
    removeSelf();
    rotate();
    scale();
    setMask();
    setReferencePoint();
    toBack();
    toFront();
    translate();
    // Common Properties
    alpha;
    contentBounds;
    contentHeight;
    contentWidth;
    height;
    isHitTestMasked;
    isHitTestable;
    isVisible;
    length; // **old**
    maskRotation;
    maskScaleX;
    maskScaleY;
    maskX;
    maskY;
    parent;
    rotation;
    stageBounds; // **old**
    stageHeight; // **old**
    stageWidth; // **old**
    width;
    x;
    xOrigin;
    xReference;
    xScale;
    y;
    yOrigin;
    yReference;
    yScale;
    // Content Size Properties
    contentCenterX;
    contentCenterY;
    contentHeight;
    contentScaleX;
    contentScaleY;
    contentWidth;
    screenOriginX;
    screenOriginY;
    statusBarHeight;
    viewableContentHeight;
    viewableContentWidth;
    // Factory Functions
    loadRemoteImage();
    newCircle();
    newEmbossedText();
    newGroup();
    newImage();
    newImageRect();
    newLine();
    newRect();
    newRetinaText();
    newRoundedRect();
    newText();
    // Group Display Objects
    numChildren;
    insert();
    remove();
    // Other Display Functions
    captureScreen();
    save();
    setDefault();
    setStatusBar();
    // Stage Display Objects
    getCurrentStage();
    setFocus();
    // Text Display Objects
    size;
    text;
    setTextColor();
    // Vector Display Objects
    strokeWidth;
    append();
    setColor();
    setFillColor();
    setStrokeColor();
class event
    memoryWarning; // *iOS only*
    // Detect Network Status
    address;
    isConnectionOnDemand;
    isConnectionRequired;
    isInteractionRequired;
    isReachable;
    isReachableViaCellular;
    isReachableViaWiFi;
    name;
    // In-App Purchases
    invalidProducts;
    products;
    transaction;
    // Runtime
    addEventListener();
    // accelerometer
    deltaTime;
    isShake;
    xGravity;
    xInstant;
    yGravity;
    yInstant;
    zGravity;
    zInstant;
    // audio
    channel;
    completed;
    handle;
    // collision
    phase;
    // completion
    action;
    blob;
    index;
    target;
    // creditsRequest
    newCredits;
    totalCredits;
    // enterFrame
    time;
    // gyroscope
    xRotation;
    yRotation;
    zRotation;
    // heading(compass);
    geographic;
    magnetic;
    // key
    keyName;
    // location(GPS);
    accuracy;
    altitude;
    direction;
    latitude;
    longitude;
    speed;
    // mapAddress
    city;
    cityDetail;
    country;
    countryCode;
    isError;
    postalCode;
    region;
    regionDetail;
    street;
    streetDetail;
    // notification
    custom;
    type;
    // orientation
    delta;
    // postCollision
    force;
    friction;
    object1
    object2
    // preCollision
    other;
    // sprite
    sprite;
    // tap
    numTaps;
    x;
    y;
    // timer
    count;
    source;
    // touch
    id;
    xStart;
    yStart;
    // urlRequest
    errorCode;
    errorMessage;
    url;
class facebook
    login();
    logout();
    request();
    showDialog();
// File I/O
// Explicit file manipulation
class file
    close();
    flush();
    lines();
    read(···);
    seek([whence] [, offset]);
    setvbuf(mode [, size]);
    write(···);
//Implicit file manipulation
class io
    close([file]);
    flush();
    input([file]);
    lines([filename]);
    open(filename [, mode]);
    output([file]);
    read(···);
    tmpfile();
    type(obj);
    write(···);
// Game Network
class gameNetwork
    init();
    request();
    show();
class graphics
    newGradient();
    newMask();
// In-App Purchases
class store
    canMakePurchases;
    finishTransaction();
    init();
    loadProducts();
    purchase();
    restore();
class json
    decode();
    encode();
    null();
class math
    abs(x);
    acos(x);
    asin(x);
    atan(x);
    atan2(y, x);
    ceil(x);
    cos(x);
    cosh(x);
    deg(x);
    exp(x);
    floor(x);
    fmod(x, y);
    frexp(x);
    huge;
    ldexp(m, e);
    log(x);
    log10(x);
    max(x, ···);
    min(x, ···);
    modf(x);
    pi;
    pow(x, y);
    rad(x);
    random([m [, n]]);
    randomseed(x);
    round(x);
    sin(x);
    sinh(x);
    sqrt(x);
    tan(x);
    tanh(x);
// Modules and Packages
module();
class package
    loaded
    loaders
    seeall(module);
require();
// Multimedia
class media
    pauseSound();
    newRecording();
    newEventSound();
    getSoundVolume;
    playEventSound();
    playSound();
    playVideo();
    setSoundVolume();
    show();
    stopSound();
    getSampleRate();
    getTunerFrequency();
    getTunerVolume();
    isRecording();
    setSampleRate();
    startRecording();
    startTuner();
    stopRecording();
    stopTuner();
class network
    // Asynchronous HTTP
    download();
    request();
    // Detect Status
    canDetecttatusChanges;
    setStatusListener;
class openfeint
    downloadBlob();
    init();
    launchDashboard();
    setHighScore();
    unlockAchievement();
    uploadBlob();
// Operating System Facilities
class os
    clock();
    date([format [, time]]);
    difftime(t2, t1);
    execute([command]);
    exit([exit_code]);
    remove(filename);
    rename(oldname, newname);
    time([table]);
class physics
    addBody();
    getGravity();
    newJoint();
    pause();
    removeBody();
    setDrawMode();
    setGravity();
    setPositionIterations();
    setScale();
    setVelocityIterations();
    start();
    stop();
class body
    // Bodies
    angularDamping;
    angularVelocity;
    bodyType;
    isAwake;
    isBodyActive;
    isBullet;
    isFixedRotation;
    isSensor;
    isSleepingAllowed;
    linearDamping;
    applyAngularImpulse();
    applyForce();
    applyLinearImpulse();
    applyTorque();
    getLinearVelocity();
    resetMassData();
    setLinearVelocity;
class joint
    // Joints
    dampingRatio;
    frequency;
    isLimitEnabled;
    isMotorEnabled;
    jointAngle;
    jointSpeed;
    jointTranslation;
    length;
    length1
    length2
    maxForce;
    maxMotorForce;
    maxMotorTorque;
    maxTorque;
    motorForce;
    motorSpeed;
    motorTorque;
    ratio;
    reactionTorque;
    getAnchorA();
    getAnchorB();
    getLimits();
    getReactionForce();
    getRotationLimits();
    setLimits();
    setRotationLimits();
// Sprite Sheets
class sprite
    add();
    newSprite();
    newSpriteMultiSet();
    newSpriteSet();
    newSpriteSheet();
    newSpriteSheetFromData();
// Sprite Instance
class spriteInstance
    animating;
    currentFrame;
    sequence;
    timeScale;
    addEventListener();
    pause();
    play();
    prepare();
class spriteSheet
    dispose();
//Storyboard
//Scene Template
class storyboard
    getPrevious();
    getScene();
    gotoScene();
    newScene();
    purgeAll();
    purgeScene();
    removeAll();
    removeScene();
class string
    byte(s, i, j);
    char(···);
    dump(function);
    find(s, pattern [, init [, plain]]);
    format(formatstring, ···);
    gmatch(s, pattern);
    gsub(s, pattern, repl [, n]);
    len(s);
    lower(s);
    match(s, pattern [, init]);
    rep(s, n);
    reverse(s);
    sub(s, i [, j]);
    upper(s);
class system
    DocumentsDirectory;
    ResourceDirectory;
    TemporaryDirectory;
    activate();
    cancelNotification();
    getInfo();
    getPreference();
    getTimer();
    hasEventSource();
    openURL();
    orientation;
    pathForFile();
    scheduleNotification();
    setAccelerometerInterval();
    setGyroscopeInterval();
    setIdleTimer();
    setLocationAccuracy();
    setLocationThreshold();
    vibrate();
class timer
    cancel();
    pause();
    performWithDelay();
    resume();
// Widget
// Bitmap Masks for tableViews and scrollViews
class widget
    newButton();
    newPickerWheel();
    newScrollView();
    newSlider();
    newTabBar();
    newTableView();
    setTheme();
// Native UI(native seems to be a JacaScript keyword!!!)
class Native
    cancelAlert();
    getFontNames();
    newFont();
    setActivityIndicator();
    setKeyboardFocus();
    showAlert();
    showPopup();
    systemFont;
    // Input Text Fields
    newTextField();
    align;
    font;
    inputType;
    isSecure;
    size;
    text;
    setTextColor();
    // Maps
    isLocationVisible;
    isScrollEnabled;
    isZoomEnabled;
    mapType;
    addMarker();
    getAddressLocation();
    getUserLocation();
    removeAllMarkers();
    setCenter();
    setRegion();
    newMapView();
    // Text Boxes
    newTextBox();
    align;
    font;
    hasBackground;
    isEditable;
    size;
    text;
    setTextColor();
    // Web Popups
    cancelWebPopup();
    showWebPopup();
