jussi:
i asked about zeus opening in maximized windows. you said this was fixed in 3.95
i downloaded 3.95v and sure enough it seems to work!
however, now i need to enter a registration code and i can't find it anywhere even though i have all the emails etc.
i was using 3.93 and i think i saw here somewhere that you didn't start using the registration code until version 3.95
if that is right, then i guess i never had a registration code.
in any case, how can i get the registration code?
omer
registration
Hi Omer,
To do this you need the transaction number and e-mail address as shown on the original RegNet registration e-mail notification.
You can then upgrade using this link and those details:
http://www.reg.net/upgrades/upgradeprod ... uthorid=75
This is correct. The version 3.95 was the first version to use a registration key.however, now i need to enter a registration code and i can't find it anywhere even though i have all the emails etc.
You need to upgrade the Zeus version from 3.93 to 3.95.if that is right, then i guess i never had a registration code.
