Double-Clicking to Select a String
Rat
Post by Rat »
When I double click a string, (no whitespace) enclosed by single quotes in a JavaScript file it selects the single quotes as well as the enclosed string.
eg. 'AString'
When the same string is enclosed by double quotes this doesn't happen.
eg. "AString"
In the Keywords options both single and double quotes are included as string delimiters.
Any suggestions...?
Any suggestions...?
Looks like a bug :(
I can confirm that this is indeed a bug :(
This issue will be fixed in the next beta release. In the mean time you can work around the issue by added single quote character to the Keywords section of the Default Document Type using Options menu ;)
This issue should now be fixed in the latest version found here: http://www.zeusedit.com/zforum/viewforum.php?f=6
