Two problems:
1) If I mouse over one of the filenames in the document tabs, it nicely provides the full pathname of the file in a tool tip. If I then move horizontally to the next tab, the tool tip for the first file remains and the second appears behind it. The first tool tip remains as I move to other tabs as long as the mouse stays in the tab bar.
2) If I make another window active and then mouse over a filename in the tab without making Zeus the active window, the filename mouse over tool tip works, but it only displays the first file when I move horizontally to other tabs. If I then click to make zeus the active window, problem 1) exists.
Again...not a show stopper...
First mouse over filename in tab remains
What is strange is if you leave the mouse alone until the tooltips pop, then from then on the tool tips work just fineIf I then move horizontally to the next tab, the tool tip for the first file remains and the second appears behind it.
Also if you click on any of the tabs with the mouse just once, then once again the tool tips work just fine.
Very strange
This issue is now fixed in the latest release found here: http://www.zeusedit.com/zforum/viewforum.php?f=6
