I just recently upgraded from 3.93 to 3.97.
How do I get the info below bottom horizontal scroll bar?
I iuse to see info like "OVR Ln:20 Col:16".
I basically want to know what column my cursor is at.
Any assistance will be greatly appreciated.
Missing botton line below horizontal scroll bar
I suspect your desktop has been setup to use large fonts and this is causing the issue
You could try changing the desktop to run using default fonts just as a test.
Also can you tell me which version of Windows you are running
Finally Could you send me a screen shot?
PS: There is a new beta version but I suspect it will not fix this issue:
http://www.zeusedit.com/z300/ze397g-beta.zip
