Hello,
Two quite minor bugs.
Greyed Menu items: Firstly when right clicking in a text edit window the context menu seems occasionally to have items that are in appropriately greyed. I won't give the whole list of items greyed, but they include: 'Open include file", Cut, copy and paste (in other words the ones I basically use).
I can't reproduce this all the time. However it seems to happen when:
I have Zeus open normally or full screen in one monitor, have many other applications open. If, for example, I click in say Notepad, and then minimise Notepad, sometimes (in fact often), if I click back into Zeus the menu items are greyed. To fix I click on a file in the work space, and the menu is restored.
This problem existed in 3.95t and is current in 3.95v.
Scrolling:
This is really minor, and doesn't really bother me, but I thought I would mention it in case masks some other problem. Scrolling down in a text window in 3.95v 'seems' to be slower than before. When I looked closely, I noticed that when at the bottom of the window with more to scroll into view, 'cursor down' scrolls the window two lines and moves the cursor down 1 line. Holding the cursor down for a repeated effect makes the screen look jumpy, which is probably why I perceive it as slower. Almost and aesthetic rather than a bug.
I have one more issue, sometimes being unable to open results in 'Searching in files', but I'll wait till I can repeat it. Otherwise Zeus is going great guns and is now the main coding platform for MonTel et al. Keep up the great work!
Regards DM
Right click context menu items greyed (and scrolling)
- Contact:
