What is Quick Help?
Here you will find links to HtmlHelp and WinHelp files that will work with the Zeus QuickHelp feature.
Locked
What is Quick Help?
The Zeus Quick Help feature offers a way to quickly search programming reference information for a keyword. For example, by placing the cursor on a function or API, the Quick Help will search the help files and instantly display the reference information for that function or API.
To see this feature in action, create a new file and add the following text to the file: FileOpenEx FileReload
Next place the cursor on each word in turn and use the Help, Quick Help menu to display the help for these items.
The Quick Help search engine supports help files written in WinHelp, HTML Help, Norton Guide Help or JavaDoc file formats.
In this forum you will find links to files and utilities that can be used by the Quick Help feature.
Locked
