Class browser without workspace or project?
Post by Guest »
I need an editor to be able to open a lot of Java and Python programs. Is it possible to get the class browser to work without creating a workspace or project for each file? Ideally, I'd like the class browser to work as soon as I open a file.
Thanks.
Unfortunately since the ctags builder is directly tied to the files contained in the project worksapce and the class browser is nothing but a display of the ctags information, there is no way to display information in the class browser without first creating a workspace :(
But the Zeus macro scripting does offer a semi-automatic work around. The following Lua macro:
--        Name: Generic Workspace
--    Language: Lua Macro
-- Description: This simple Lua macro is designed to create a project
--              for nothing but the current file. To use this macro
--              will require the following once of initialisation:
--                 1) Run the macro to create the workspace
--                 2) Use the Workspace Open menu to open the newly
--                      created Generic workspace
--              Once the workspace is created and is open all you need
--              do is open any file and run the macro. The macro will
--              recreate the workspace and upfate the class browser to
--              reflect the current file only.
function create_project_workspace(filename)
    -- open the workspace file
    file_workspace = io.open("c:\\temp\\generic.zwi", "w+")
    if file_workspace ~= nil then
        -- create the workspace file
        file_workspace:write("<workspace name=\"Generic\">\n"                        )
        file_workspace:write("    <mode></mode>\n"                                   )
        file_workspace:write("    <active>Generic</active>\n"                        )
        file_workspace:write("    <project name=\"Generic\">c:\\temp\\generic.zpi</project>\n")
        file_workspace:write("</workspace>\n"                                        )
        file_workspace:close()
        -- open the project file
        file_project = io.open("c:\\temp\\generic.zpi", "w+")
        if file_project ~= nil then
            -- create the project file
            file_project:write("<!-- Generic project file for the Zeus for Windows editor.-->\n")
            file_project:write("<project name=\"Generic\">\n"                           )
            -- add the file to the workspace here
            file_project:write("    <file>" .. filename .. "</file>\n"                  )
            file_project:write("</project>\n"                                           )
            file_project:close()
            -- failed to create file
            message_box(1, "Error creating the 'c:\\temp\\generic.zpi' file")
        message_box(1, "Error creating the 'c:\\temp\\generic.zwi' file")
  -- This macro will only work for document windows.
  local document = is_document ()
  if (document == 0) then
     return 1
  -- get the current text details
  local filename = macro_tag("$fn")
  -- NOTE: Read the special initialistion section in the macro header
  -- close the generic workspace
  WorkspaceClose()
  -- create an empty workspace
  -- reload the newly generic workspace
  WorkspaceReload01()
key_macro()
automatically creates a workspace containing nothing but the current file. If you bind this macro to the keyboard you can update the class browser display with a single key press :)
Note:Unfortunately this macro is not as seamless as it should be and it does require minimal initialisation :( For details see the header information of the macro source.
In the process of writing of this macro I realised there is no way to open a named workspace using a scripting function. Unfortunately without such a function it is not possible to make the integration seamless :(
But I will make sure a new workspace_open(filename) macro function is added, enabling a more seamless interface :)
