Jussi,
I've recently been working on a project generating API style documentation for a set of COBOL programs. I've got this done, and can generate a CHM file that works as a quick help file for the set. So far so good.
My observation is that when I regenerate the CHM file, Zeus can no longer reference it reliably. Sometimes that seems to mean not at all, other times it means that it can find topics, but the help display shows no contents or index tab. Is this what I should expect?
Is there a utility or macro function that I might use to tell Zeus to refresh? I guess I could put one together using AutoHotKey or something, but an "official" procedure might be more reliable.
Bill
Quick Help functions
Are you sure that the CHM file you created contains valid index information
No.Is there a utility or macro function that I might use to tell Zeus to refresh?
All Zeus does is read the index information from the CHM file and it then uses this information as a basis for the Quick help search.
It does this at the time the file is first added to the Quick Help for the document type.
So for example if you use the Help, Contents menu to bring up the Zeus CHM file you will see an Index tab in the CHM viewer.
You can do a Quick Help that will work for any Zeus keyword (or partial word) displayed in this index.
So if you load up one of your CHM files in the Viewer and it does not contain an Index tab or that Index tab is empty then that is the problem you are seeing.
