AgentSVN and Microsoft SCC-Add-In for MS Access 2010
Josef
Post by Josef »
Hi!
Is it possible to use AgentSVN with the Microsoft SCC-Add-in vor Access 2010?
The Microsoft SCC-Add-In implements MSSCCI.
I could not use AgentSVN for this add-in. This is currently not possible or did I something wrong?
Note: With UnifiedSCC (Aigenta) I can use the add-in from MS. But there are some problems with it, so I'm looking for an alternative.
Josef
The link to the plug-in you posted suggests the plug-in allows Access to work with Visual Source Safe.
This suggests to me that Agent SVN should also work, since it implements the same Visual Source Safe interface ;)
Josef
Post by Josef »
This Add-In also allow Access to work with Subversion, because it use the MSSCCI.
I was also this opinion before I tested some programs. :D
But now I found another MSSCCI provider and can use Subversion without bugs. :)
Josef
So what bugs did you find and which programs did you test it with :?:
The Agent SVN has not been tested against Access, but it has been tested against Visual Studio, Visual C++, SQL Studio Management and Zeus and it works just fine ;)
NOTE: The Agent SVN plug-in uses SVN itself so this does require the user to correctly configure SVN for the plug-in to work and getting SVN to work can be quite tricky. But there are configuration steps outlined in the help file.
Post by Guest »
This is a problem with the SCC Add-In for Access. Some MSSCCI provider will not work with this Add-In.
Note: The SCC add-in exports the access objects as individual files in a folder. These files are used for check-in/check-out.
My first test: UnifiedSCC ... check-in/check-out worked, bug: revert (from previous revision) failed
TamTam: no comment ;)
AgentSVN: If I use AgentSVN, the Access objects will not be exported. => check-in/check-out fails because there are no files to check-in.
PushOk SVN Proxy: Currently I found no problem.
Josef
Hi Josef,
My guess is the SVN environment might not be setup quite right :(
If your interested there is this key in the registry:
HKEY_CURRENT_USER\Software\Xidicone\Agent SVN\HelpDebug
If you set this flag to 1 then a log file will be produced in the C:\Program Files\AgentSVN folder and it should give you a bit more information as to why the check in/check out is not working.
If you e-mail me this log file I will also be more than happy to take a look at it :)
