Jussi,
I like the new tags-based syntax coloring, but I haven't used it enough to know whether the performance hit in (my) normal usage will work for me. Anyway, a couple of questions:
1) Would it be possible to use the workspace tag type labels on the tag type coloring selection dialog? I normally use a scheme of COBOL tag type names, and can never remember the match up without going a looking. This might be a bit problematic since I assume tags-based syntax coloring is document type based and tag type labels are project(?) or workspace-based. Perhaps if you use the labels for the current project? That's not ideal, but I can't think of anything else.
2) Is there a reason why Prototypes were excluded from the syntax tag coloring? I label them Files, which could be a handy coloring item in COBOL.
Bill Diener
Tags Syntax Coloring
Hi Bill,
This is 100% correct. Unfortunately, these names also appear at the bottom of the Category listbox in the Coloring panel, which makes them fairly tricky to change
Because each tag lookup does slows down the painting, for this first version, not all the tags where added. But I will look to add the prototypes to this listIs there a reason why Prototypes were excluded from the syntax tag coloring?
