Using Zeus for many years i tried to upgrade to V397. That version ignores the -i and -u parameter that works with 396 perfect. my commandline is
"D:\Zeus397\zeus.exe -ug:\up\up51\work -ig:\up\up51\work\ZeusUp51.ini"
When I use 397 instead of 396 (the installations have the same structure) it always uses the default zeus.ini.
Can you help me
Greetings from Vienna, Austria
Herbert Kern
INIFile and other commandline switches not accepted
Hi Herbert,
Greetings from Sydney, Australia.
The V397 release was changed to support the Vista DAC (i.e. user settings could no longer be saved to the c:\program files\zeus folder as it was now protected) and this change broke the command line code
I will look to have this bug fixed in the next patch
I can confirm this is a bugUsing Zeus for many years i tried to upgrade to V397. That version ignores the -i and -u parameter that works with 396 perfect.
Re: INIFile and other commandline switches not accepted
Thanks, it is very interesting to know the cause, I can wait.kernbert wrote:Using Zeus for many years i tried to upgrade to V397. That version ignores the -i and -u parameter that works with 396 perfect. my commandline is
Can you help me
Herbert Kern
But I have another minor problem already for some years. I will post it under "Problem with german special fonts" because I am so excited that your response was so fast.
Herbert Kern
Hi Herbert,
A new Zeus 3.97d beta version that should fix this isssue can be found here: http://www.zeusedit.com/z300/ze397d-beta.zip
