BackspaceSmart on first column .. CPU Hogging
rl
Post by rl »
Hi
I've found that when Backspace is pressed while bound to BackSpaceSmart and the cursor is positioned on the first column in a line, Zeus' CPU utilisation jumps to 99% - 100% and stays there until I end-task with TaskManager.
It doesn't happen if Backspace is bound to BackSpace or BackSpaceEx, or if the cursor is on any column other than the first.
Richard
There is no doubt you have found a bug in the BackSpaceSmart keyboard function :(
But as you suggest, the easy work around is to bind the backspace key to some other keyboard function other than the BackSpaceSmart keyboard function.
The latest version of Zeus found here should hopefully fix this issue: http://www.zeusedit.com/forum/viewforum.php?f=6
