Hello,
the folding feature coming with Zeus I like a lot.
Unfortunately I have to edit C-sourcecode files with uncommon extensions, so folding does not work with this files.
Is it possible to configure that all files having extension .tdf, .cdf or .pcd get the same folding options like ordinary .c files?
Can I configure this myself or do I need a special dll for this?
It would be a great feature, if the user can configure, how specific fileextensions behave on folding.
Many thanks for any hint!
Sergeant
How to fold like C-sourcecode:extension .tdf,cdf,pcd
Currently the only way to do this is via a new dll. Watch this space for a new dll.Can I configure this myself or do I need a special dll for this?
Eventually the plan is to make the folding more user configurable.
The code folding for changes have been madeand the new xFolder.dll can be found here:
To install this new dll backup the current dll and replace it with the one contained in the zip file.
To complete the install you will need to add these file extensions to a document type and enable the code folding option.
This version creates a xFolder.ini to the Zeus install directory and this file can be used to add new file extensions
