I would like to suggest getting rid of the "Name" column in the Tags Search Results display window. This column doesn't provide any useful information (as far as I can see) as its always the same as the "Tag Name" box. You can leave the icon symbol in the Name column - although I don't know what these icons mean.
And as suggested previously, I would like to be able to change the size of the Tags Search Results window.
Alternatively (or in addition), the Tags Search Results could be presented in the Navigator. If this is done, the Navigator should switch to the TagsSearchResults each time a Tags search is done.
A Tags Search results Navigator panel could be part of a "general" search result - I would like to be able to search for anything in the Navigator - a function, variable, macro, tag, file - whatever matches my search criteria - even if the type is different. For example, I could be looking for a function name, but if a filename also matches, then show that too - the Navigator could show a tree of types that are found - the tree should be showing all branches.
Tags Search Results
The Tag Name entry field accepts a '*' wild card character at the end (i.e. MyTag*) in which case the Name column becomes very importantI would like to suggest getting rid of the "Name" column in the Tags Search Results display window. This column doesn't provide any useful information (as far as I can see) as its always the same as the "Tag Name" box.
