i just downloaded the zip file and unzipped it to the '\program files\zeus' directory.
Now when i try to run it i get the message:
c:\programdata\xidicone\zeus\
Unexpected error locating Zeus application installation data.
i am running Vista Ulitmate.
i looked in the programData directory and there is no xidicone directory.
this is a patch to 3.96s
thanks,
Bill
zeus 3.97
Hi Bill,
Are you trying to upgrade a current install or are you trying to do a first time install
If this is a first time install, just run the full installer found here: http://www.zeusedit.com/download.html
These patch files are provided to help upgrade a previous Zeus installation, but unfortunately they only work for Windows XP and not for Vista. Unfortunately on Vista the Zeus software upgrade process is a little more complex
I have create a help link that describes Vista installation and upgrade process in more detail: http://www.zeusedit.com/forum/viewtopic.php?p=4970
If you are trying to upgrade the Zeus software on Vista refer to the upgrade section of this link.
