how to set response timeout ? and what is default value?
In nearly all cases Zeus tries to make sure the paint messages are processed so Windows should not report Zeus as not responding.
Also for long operations, Zeus tries to keep the user informed by displaying feedback in the status bar.
You can also cancel any Zeus operation with the
Abort keyboard function (i.e mapped to the
Ctrl+Break keyboard keys).
Now, having said that, there may well be cases where this is not happening, in which case I suspect you have found a bug
Can you tell me which part of the Zeus functionality is causing the software to hang
