lua string.format
valtoni
lua string.format
Post by valtoni »
I'm trying to write a macro to get the name of a function in C code, but every time I use the function
string.format("%c", ... )
, I get the following error message:
attempt to index local `string' (a nil value)
I'm using Zeus v. 3.93.
Valtoni
There is an example of the string.format function in the c:\Program Files\Zeus\zScript\char.lua file.
I checked this script and it ran fine for me.
You are running a very old version of Zeus, which will also means you are running a very old version of Lua.
If the script above does not run on your version of Zeus you might in fact be seeing a bug in Lua itself :?
