Fill marked down, right (Insert/Over), 4 Lua scripts
petar12345
Post by petar12345 »
Find below four very nice Lua scripts written by Petar Turkovic 8)
I edited Petar's original posting by splitting the scripts into four individual post and adding a few examples to make them easier to understand ;)
I also made a few minor changes to the scripts (i.e. search for the JAJ comments) to make the scritps run correctly without the need for the Brief column paste mode editor option.
Lua script written by: Petar Turkovic
The f_FillDnIns.LUA takes a marked area and takes the contents of the first line of the marked area and inserts it into all the other lines defined by the marked area.
So for example take the following text and mark the first three columns of all these lines:
SetText1(String &szBuffer);
Text2(String &szBuffer);
Text3(String &szBuffer);
Text4(String &szBuffer);
Running this macro results in this new text:
SetText2(String &szBuffer);
SetText3(String &szBuffer);
SetText4(String &szBuffer);
Here is the f_FillDnIns.LUA code:
--  PROJECT      : A5: Lua Macro
--  PROGRAM      : f_FillDnIns.LUA  Fill Down Marked Area - Insert
--  PROJECTOR    : Turkovic Petar
--  PROGRAMER    : Turkovic Petar
--  VERIFICATION : Jussi Jumppanen
-- == Standard: ===========================================================
--  07.07.09  A5.50.1.1.2
-- == Description: ========================================================
--  This a simple Lua macro will fill down first row in the marked area.
--  Insert, shift text right
------ Version_5 ----------------------------------------------------------
  if is_marked() == 0 then
    message("This macro needs a column marked area.")
  local l_top     = get_marked_top()
  local l_left    = get_marked_left()
  local l_bottom  = get_marked_bottom()
  local l_right   = get_marked_right()
  if l_top == l_bottom then
    message("This macro needs at least 2 lines in marked area.")
  if l_left == l_right then
    message("This macro needs at least 1 column in marked area.")
  -- disable screen updates
  cursor_save()
  MarkHide()
-- copy first row
  set_line_pos(l_top)
  set_cursor_pos(l_left)
  MarkColumnToggle()   -- start marking
  set_cursor_pos(l_right)
  MarkCopyEx()         -- copy marked area to clipboard
-- fill marked area
  for i = 1, l_bottom - l_top, 1 do
    -- JAJ position the cursor and don't rely on brief paste mode
    set_line_pos(l_top + i)
    MarkPasteEx()
-- mark area
  set_line_pos(l_top)
  set_line_pos(l_bottom)
  cursor_restore()
  -- restore screen updates
The f_FillDnOver.LUA takes a marked area and takes the contents of the first line of the marked area and overwites the text into all the other lines defined by the marked area.
GetText2(String &szBuffer);
GetText3(String &szBuffer);
GetText4(String &szBuffer);
Here is the f_FillDnOver.LUA code:
--  PROGRAM      : f_FillDnOver.LUA  Fill Down Marked Area - Over
--  Fill over marked text
  cursor_save()
  MarkHide()
-- copy first row
  set_line_pos(l_top)
-- delete marked text
  set_line_pos(l_top + 1)
  MarkDelete()
-- fill marked area
    MarkPasteEx()
-- mark area
  set_line_pos(l_top)
  cursor_restore()
The f_FillRightIns.LUA takes a marked area and takes left most character and insert it into the contents of each of the lines contained in the marked area. It uses the with of the marked area to determine how many times the first character need to be inserted.
So for example take the following text and mark the first four columns of all these lines:
SSSSetText1(String &szBuffer);
SSSSetText2(String &szBuffer);
SSSSetText3(String &szBuffer);
SSSSetText4(String &szBuffer);
Here is the f_FillRightIns.LUA code:
--  PROGRAM      : f_FillRightIns.LUA  Fill Right Marked Area - Insert
-- == Standard: ============================================================
-- == Description: =========================================================
--  This a simple Lua macro will fill right first column in the marked area.
--  Insert, shift marked text right
------ Version_5 -----------------------------------------------------------
  -- JAJ changed 2 to be 1
  if l_right <= l_left + 1  then
    message("This macro needs at least 2 column in marked area.")
  cursor_save()
  MarkHide()
-- copy first column
  set_line_pos(l_top)
  set_cursor_pos(l_left + 1)
-- fill marked area
  for i = 1, l_right - l_left - 1, 1 do
    set_line_pos(l_top)
    MarkPasteEx()
-- mark area
  set_line_pos(l_top)
  cursor_restore()
The f_FillRightOver.LUA takes a marked area and takes left most character and overwrites it into the contents of each of the lines contained in the marked area. It uses the width of the marked area to determine how many times the first character need to be inserted.
GetText1(String &szBuffer);
GGGGext1(String &szBuffer);
GGGGext2(String &szBuffer);
GGGGext3(String &szBuffer);
GGGGext4(String &szBuffer);
Here is the f_FillRightOver.LUA code:
--  PROGRAM      : f_FillRightOver.LUA  Fill Right Marked Area - Over
  cursor_save()
  MarkHide()
  set_line_pos(l_top)
  set_line_pos(l_top)
  MarkDelete()
-- fill marked area
    set_line_pos(l_top)
    MarkPasteEx()
-- mark area
  set_line_pos(l_top)
  cursor_restore()
petar12345
When I start learning Lua I read examples like this.
If that example have lines like ones which I delete, with no functionality but that lines not generate bug in execute, I was confused much better.
I was not see why this lines are there, I was know so litle about lua.
In that case I read that example over and over to try find why that lines must be there.
Please insert new code over old ones.
Edited by jussi: I have updated these macros with your new versions. Nice work ;)
By!
petar12345
This is my favorite one. New one. 8)
The f_FillDnLineIns.LUA takes a marked area and takes the entire contents of the first line of the marked area and inserts multiple copies of that line into the document. The number of copies of the line that are inserted is determined by the number of lines of the original marked area.
Running this macro will result in the following new text which includes 3 new lines:
Here is the f_FillDnLineIns.LUA code:
--  PROGRAM      : f_FillDnLineIns.LUA  Fill Down Line - Insert
--  VERIFICATION :
--  08.07.09 19:47   A5.50.1.1.2
--  This a simple Lua macro will fill down first line in the marked area.
--  Lines will be inserted
  local l_line
  MarkHide()
  set_line_pos(l_top)   -- cursor in first line
  l_line = get_line_text() -- get first line text
    MoveDocumentEndEx()  -- Cursor to end of line
    print("\n")            -- New line
    MoveDocumentStartEx()  -- Cursor to start of line
    print(l_line)
  set_cursor_pos(1)
  MarkLineToggle()   -- start marking
  set_line_pos(l_top)
