column editing
rasillion
column editing
Post by rasillion »
The main reason I want to use Zeus is column editing. A previous forum exchange on the subject explained exactly what I need:
Posted: Sun Sep 24, 2006 7:08 pm Post subject: column editing
Does Zeus allow column editing?
Some very clunky and inconvenient work arounds were suggested but then the "admin" posted:
Posted: Mon Sep 25, 2006 11:22 pm Post subject:
I have added this feature request to the Zeus todo list
This was over 3 years ago and yet I do not see column editing a la Brief, Codewright, JEdit.
1. Is it there and I just do not see it?
2. If not, do you actually intend to add it?
I am assuming you are referring to this earlier posting: http://www.zeusedit.com/forum/viewtopic.php?t=972
Unfortunately this feature is still on the todo list :(
rasillion
too bad
Post by rasillion »
Yes, that is the earlier posting.
Too bad you haven't done it because I like the rest of Zeus but cannot and will not program without column edit.
thanks anyway
Alan
The Fill Down and Over (i.e f_FillDnOver.lua) Lua scripts written by Petar Turkovic implements something similar to this ;)
IMHO Petar's script does a very nice job of implementing exactly this functionality ;)
But it is a scripting option, which probably means you'll also consider it to be clunky and inconvenient work around :(
In any case the script can be found here.
