Hello,
I've been using UltraEdit for a few years, but I don't like the fact that it doesn't seem able to save all temporary files to a given directory, which makes it hard to re-open temporary files after a crash or I had to kill UltraEdit to restart Windows.
So... I'm looking for an alternative with the following features:
- Native Windows app
- Loads fast
- Saves all temporary files, in one directory (I like just copy/pasting text from the clipboard without saving each window into a file)
- Syntax highlighting (HTML, Python, Delphi, etc.)
- Shows list of open documents in left-hand list, Explorer style
- Good search/replace regex
Does Zeus fit the bill?
Thank you.
Looking for UltraEdit alternative
In the 15+ years that I have been running Zeus I can only remember ever losing one or two files due to a crash.I've been using UltraEdit for a few years, but I don't like the fact that it doesn't seem able to save all temporary files to a given directory, which makes it hard to re-open temporary files after a crash or I had to kill UltraEdit to restart Windows.
That is not to say that in all this time Zeus has never crashed, it most certainly has
But when Zeus crashes it generally does not terminate, which means that there is a good chance that one of the file save, file save as or file select all and copy to clipboard operations will recover the data in the file
Having said this, I don't think there is any excuse for software crashing and as far as I can tell Zeus DOES NOT crash on any sort of regular basis. It should be very stable.
Zeus is a stock standard Win32 windows application.- Native Windows app
Having never used Ultraedit I can answer this one. As far as I can tell Zeus seems to be fast loading.- Loads fast
NOTE: Zeus is not a very large file editor so files of the size of 100 mBytes or larger might feel slow loading.
By default all file go to the zBackup folder. See the Options, Editor Options, Backup panel for other backup options.- Saves all temporary files, in one directory (I like just copy/pasting text from the clipboard without saving each window into a file)
Baring configuration errors the syntax highlighting supports these languages.- Syntax highlighting (HTML, Python, Delphi, etc.)
You can use the Options Document Types menu, Compiler panel to configure the error, warning and information details for any given file extension.Any errors can be easily fixed as the highlighting is fully configurable.
Zeus has a left hand drive navigator panel and also a left hand side files navigator panel.- Shows list of open documents in left-hand list, Explorer style
You can also navigate to files using the file buffer dialog using the View Document List menu.
Zeus uses the Unix/Perl style of regular expressions.- Good search/replace regex
I would say it doesDoes Zeus fit the bill?
But Zeus does runs fully function for 45 days so it is quite easy for you to check out Zeus for yourself
http://www.zeusedit.com/download.html
Also if you find any of the information posted above to be incorrect or confusing, feel free to post any corrections or furthur questions to this thread.
Sorry for the wrong expression: I meant that I often copy/paste text into unnamed files, and I like the fact that I can just kill the app without having to save each and everyone of them (eg. when Windows bothers me one time too many with its Update feature, and forces me to reboot) and expect the files to be reopened when I restart the app.jussij wrote:In the 15+ years that I have been running Zeus I can only remember ever losing one or two files due to a crash.
I'll check if Zeus supports this, as this is a must-have feature for me.
Thanks for the feedback.
When you close Zeus it will ask you to save any unsaved files and any new unnamed files do fall into the category. So it will also prompt for a save on close.
But I also tend to have a lot of unnamed text files open and I have never found this too annoying.
In fact I understand how this can be very annoying. For example the File Save All functionality in Zeus used to save all the files and it this would result in a lot of these save as message boxes.
This annoyed me so much I change the save all to only save named files making it message box free
For the next Zeus release there will be the following new keyboard functions:I meant that I often copy/paste text into unnamed files, and I like the fact that I can just kill the app without having to save each and everyone of them.
WindowCloseAllNew
WindowCloseAllOutput
The WindowCloseAllNew function in particular will provide a way to close all the unnamed windows without being prompted with a request to save
