german keyboard
dafire
german keyboard
Post by dafire »
zeus is not working with a german keymap... to get braces like { [ ] } you need to press "Alt Gr"+7 "Alt Gr"+8 "Alt Gr"+9 "Alt Gr"+0 and for an @ you need to press "Alt Gr"+Q ...
Alt Gr is the right alt key.
If I press "Alt Gr"+Q in the Keyboard Mapping Menu it says I pressed Atl+Ctrl+Q and it's not defined..
nice editor but unusable for me :(
This is an unfortunate Zeus configuration bug :(
But fortunately this bug is easy to fix: )
If you do the following:
  1. Options, Editor Options menu
  2. Select the General panel
  3. Check the Display Alt key codes option
  4. Check the Display Ctrl key codes option
then the keyboard should work correctly :)
Post by Guest »
thanks.. I really begin to like zeus ....
