Align Text Macro
Align Text Macro
This script below will align code to a given vertical cursor location. specified.
For example assume you code looks like this where | is used to indicate the cursor location:
        Some |            text
        that      is
        all    over
        the           place
Putting the cursor at the | location and running the macro four times gives you the nicely aligned code shown below:
        Some text
        that is
        all  over
        the  place
--        Name: Align  Macro
--      Author: Omer Kircher
--    Language: Lua Macro
-- Description: This function facilitates lining up columns of text.
--              To use, load the macro (i.e. F9 key), position the cursor
--              and then run macro using the Macro Execute (i.e. F8 key)
--              Alternatively you can bind the macro to the keyboard.
--              Blank spaces between the cursor and the next word will
--              be deleted.
--              The cursor is then moved to the next line ready for
--              another operation.
    -- look for a white space (32) ascii character
    if get_char_at() == 32 then
        -- remove the white space
        MarkColumnToggle()
        MoveWordNext()
        MarkDeleteEx()
    -- position the cursor on the next line
    MoveLineDown()
