how configure Zeus for LUA projects?
Nut
Post by Nut »
The first How configure Debuger :?:
The Zeus debugger support is based around the semi-standard GDB style of command line debugger interface. I am not sure if there is in existence a GDB based Lua debugger, which would mean this configuration will be a little difficult :(
I think you might be better of opting to use some sort of stand alone Lua debugger (if such a thing exists) and either setting up a Zeus tool to start the debugger, or alternatively using the debugger options of the workspace to define the debugger command line.
Cheers Jussi.
Nut
Post by Nut »
What a pity!
Thank you.
Zeus can now debug Lua code.
There is an example video on this page: http://www.zeusedit.com/lua.html
