WOrkspace no long in alphabetical order
Jack Rosenbloom
Post by Jack Rosenbloom »
I recently upgraded from 3.93 to 3.95. When I use the menu command "Add Current File To Folder", the file is added at the end of the existing files in the workspace folder. Version 3.93 kept files in alphabetically order.
Jack
Hi Jack,
To fix this you need to do the following:
  1. Close the workspace.
  2. Open the project file zwi file in something like notepad, or Zeus itself if you use the File Open menu
  3. Change the sorted attribute of the project to be Yes from No
  4. Save the file changes and close the file
  5. Reopen the workspace in Zeus
You will only need to do this the one time and you should now see the files for that project are displayed in alpabetical sort order.
By default any new project would have sorted already set to Yes, but because your project was a 3.94 vintage it took on the value of No, which is a bit of a bug :(
With regard to this issue, it turns out the sorted attribute is found in all projects, workspaces and folders. So to fix the sorting you need to edit the zwi and the zpi files and change all occurrence of the sorted attribute to yes.
