I wanted to use Zeus and WinAVR Compiler which is based on a UNIX gcc compiler. To make compilation successfull I need a makefile placed in the current folder. This is done. The problem is following: when I open cmd.exe in yhe project folder end execute make.exe it works fine. When I execute from a Start menu: C:\WINNT\system32\cmd.exe /c make.exe -C HERE PATH TO THE PROJECT FOLDER
but when I place C:\WINNT\system32\cmd.exe /c make.exe -C HERE PATH TO THE PROJECT FOLDER to the Compiler->Options->Command line and press the Compile button then it doesn't work. There is following message in the Compile window:
Zeus for Windows Programmers Editor - Version 3.95
Copyright (c) Xidicone Pty Ltd 1993-2005. All rights reserved.
--------------------Configuration: led - Release--------------------
make.exe: Entering directory `c:/dokuments/projects/led'
avr-gcc -g -Wall -O2 -mmcu=atmega8 -Wl,-Map,demo.map -o demo.elf demo.o
process_easy: DuplicateHandle(In) failed (e=6)
make.exe: Interrupt/Exception caught (code = 0xc0000005, addr = 0x422307)
I don't know why. Am I doing something wrong? How to set the compiler settings?
thx
