A Few Questions
pwdiener
A Few Questions
Post by pwdiener »
1) In the class browser, things are almost always listed in alphabetical order. However, in a few cases, things are listed in reverse alphabetical order. I've only seen this when expanding a project file (i.e. level 3 of the tree, not level 2). Should they be in ascending order or is the order not specified?
2) Every time I do a new Find, the match case sensitive option is set. I've tried a couple things to get it reset, but don't seem to have found the right one. Where should I look?
3) For COBOL, I have a function regex defined. When I select View/Functions, I get a window showing all the "functions" in the file. When I click the Functions in the Navigator, I get a message that says "Function list is not applicable for this document." Is this as expected?
4) Is there any way to save the window state (splits, arrangement, etc) when exiting?
Bill Diener
1) Should they be in ascending order or is the order not specified?
I will have to check this out. I would have assumed they where displayed in ascending order :?
This is bug: http://www.zeusedit.com/forum/viewtopic.php?t=1912
3) When I click the Functions in the Navigator, I get a message that says "Function list is not applicable for this document." Is this as expected?
Yes ;)
Here is a description as to why this is so: http://www.zeusedit.com/forum/viewtopic.php?t=1275
Unfortunately not :(
The first two issues raised in this post have been fixed in the latest patch found here:
http://www.zeusedit.com/forum/viewtopic.php?p=3976
