problem with search and replace
gwgs
Post by gwgs »
find: l
replace: self.l
replace all=infinite loop (see result)
sample code
l=1
result:
self.self.self.self.self.self.self.self......self.self.self.l
search position is not moving to end of replaced block before finding next occurrence.
find: self.l
replace: l
replace all
sample code:
self.l=self.l-1
result:
l=self.l-1
second occurrence not found at all, until you move cursor to before txt to be replaced.
Grant
Hi Grant,
Thanks for posting this bug report. This bug will be fixed in the next Zeus patch release ;)
