creating a new document
alanm
Post by alanm »
hi,
When I want to cretae a new document I click on file, new. However this brings up the default document which in my case is sql. I want to start a new html document, how is this done?
regards
Alan
Use the Options, Editor Options menu, General panel and in the Default File New extension entry field set the extension to be html ;)
alanm
Post by alanm »
many thanks for the help
alan
The latest version of Zeus now has a shortcut method of creating a file of a given extension.
To create a new document of a given file extension you would do the following:
1) Select the Templates panel.
2) Select the Document Type required from the drop down list.
3) Click on the New File template.
NOTE: With a bit of tweaking it is also possible to control the contents of the newly created file by editing the template document for that extension.
