I am using Zeus 3.96o on WindowsXP. I am using the Brief keyboard.
I select some text using the ALT-M, arrow over to select some text, then do an Alt-S and seach from some char before the end of the line.
What happens is my original selection is thrown away and the char I am searching for is selected.
What I had expected and what has worked for me with other brief editiors is that my original selection up to and including the char I searched for would be selected.
Selection dropped when doing a search
Unfortunately I am not really sure what you mean by original selection being thrown away
It's has been a very long time since I used the original Brief so I might more than likely forgotten how it actually worked ;?
This is what I did:
- Set Brief as active
- Opened a document
- In the middle of the first page and in the middle of that line start marking with Alt+M
- Use the keyboard right arrow to selected a few characters[/B]
- Alt+S to bring up the search dialog.
What I had expected and what has worked for me with other brief editors is that my original selection up to and including the char I searched for would be selected.
For me the marked area is retained and the search dialog is displayed with the highlighted text displayed in the find text entry field.
If I had selected more than one line then the search text would still have been retained but the Market text only option of the search dialog would have been selected.
<this is the original line>
select the "<this" with the ALT-M and then arrow over
then ALT-S and seach for ">"
Now the whole line should be selected.
You might ask why would I want to do this? The answer is that when you are creating a macro you often need to search for a delmiter and keeping the selection of text, so that one can copy or delete is important.
Ok, I now understand what you mean. I must admit I don't remembered using this Brief feature, but it is definitely a nice feature to have
Unfortunately the current searching does not support this feature
But I think it should be easy enough to add a Maintain seletion check box to the find and replace dialogs to allow for this behaviour
This feature has been added to the latest Zeus release found here: http://www.zeusedit.com/forum/viewtopic.php?t=2118
