Hi
I have just upgraded to version 3.96o. (from 3.95z)
I am hoping that I that I have missed something in the configuration and there is a simple switch to change this:- it is that the Navigator buttons take up too much screen real estate.
I only use the workspace in any event, and so even the tabs of 3.95 were not something I needed, but at least they were small. My workspace has to be scrolled on my monitor and so I need every pixel I can get.
And as nice as those new navigator buttons are -- I can see where I might emulate them in my code -- I find they catch my eye a tad too much on my classic Windows 2000 system.
Is there a setting to hide the buttons?
As I suspect, if not, could such a feature be included please?
regards DM
Navigator buttons
- Contact:
Hi David,
Welcome to version 3.96
Make sure you are running version 3.96o and also remember to occasionally check for newer version in the announcement section of this forum.
Unfortunately not
I have added this feature to the Zeus todo list
Unfortunately not
- Contact:
Navigator buttons
Hi...could such a feature be included please?
I have added this feature to the Zeus todo list![]()
Have you made any progress on this? I'm still using 3.95z.
Perhaps an option to use the old tabs might be useful too, but I'm happy to only use just the Workspace in Navigator.
regards DM
- Contact:
Hi, thanks. Those check boxes are a great addition - and solves most of my issue. However, they don't make the buttons go away.There is now a option to hide these buttons using the Options, Editor Options menu, Micellaneous panel![]()
The original 3.95 tab interface takes less real estate than the buttons, and I find that preferable. I would love to see that re-incorporated, even as just an option.
regards DM
