More than one set of code folding keywords
emh203@psu.edu
Post by emh203@psu.edu »
Hello:
I just submitted a request for code folding for verilog (which was promptly added). Is it possible to add another set of keywords for verilog that will also code fold?
Will future versions have the ability to make code folding user definable?
-Eli
The Verilog folding that was added should fold these start of fold markers:
begin
attribute
case
casez
function
module
primitive
specify
table
task
and these end of fold markers:
endattribute
endcase
endfunction
endmodule
endprimitive
endspecify
endtable
endtask
If there are fold markers missing or you find any problems with the folding behaviour just post a message to this forum.
As you have seen, the time and effort in adding a new language is minimal, while the effort required to code, test and document a user configuration layer would be much greater.
So for the mean time there are no plans to make this feature user configurable.
