restoring file types after installing Zeus
stenl
Post by stenl »
After installing Zeus, my extensions now is called "Xidicone Zeus Document" instead of "c-file", "h-file" etc.
This means I can no longer sort on file extensionl - they are all "Xidicone Zeus Document".
How can I restore this?
sten
Find the HKEY_CLASSES_ROOT\ZeusDocument key using regedit.exe utility and change the (Default) value to be an empty string.
If you now re-start windows the file types should be return to their default display values.
