Verilog Code Folding Description
emh203@psu.edu
Post by emh203@psu.edu »
Extension: .v
Line Comment: //
Block Comment: /* */
Begin: BEGIN
End: END
Sample Code:
module test(clk, enable, value)
input clk;
input enable;
output [7:0] value;
reg [7:0] count;
always @(posedge clk)
begin
if(enable == 0)
count <= 0;
count <=count + 1;
endmodule
The code folding for Verilog has been implemented and the new xFolder.dll can be found here:
http://www.zeusedit.com/z300/xfolder.zip
To install the new folding dll:
  1. Make a backup copy of the current xFolder.dll and replace it with xFolder.dll from the link above
  2. Create a Verilog Document Type.
  3. Open a Verilog file
  4. Turn on code folding using the View, Folding, Folding Margin menu.
NOTE: There is a limitation in the Zeus folding feature in that it never expects to see a end and a begin fold on the same line. To understand what this means consider this snippet of Verilog code:
 if (~reset) begin
   q <= 1'b0;
 end else begin
   q <= data;
This code will fold incorrectly because of the end else begin line. For the folding to work correctly the code needs to be re-formated as follows:
 if (~reset) begin
   q <= 1'b0;
 begin
   q <= data;
emh203@psu.edu
Just tried it out and it works great! Thank you for the great response time. I have been looking for this feature for awhile. I will definately buy this software!!
