Extension: .prg .h .ch
Line Comment: //
Block Comment: /* */
Begin: begin sequence
End: end sequence
Begin: if
elseif
End: endif
Begin: for
End: end
Begin: function
End: return
Begin: procedure
End: return
Begin: do case
case
otherwise
End: endcase
Begin: do while
End: end do
PROCEDURE Main
LOCAL nMenuItem
@ 2, 1 PROMPT " DBF file "
@ 4, 1 PROMPT " NTX file "
@ 6, 1 PROMPT " Search "
MENU TO nMenuItem
SetPos( 0, 0 )
DO CASE
CASE nMenuItem == 1
? "selects DBF file"
CASE nMenuItem == 2
? "selects index file"
CASE nMenuItem == 3
? "searches data record"
OTHERWISE
nMenuItem := Alert( "Exit program?", ;
{" Yes "," No " } )
SetPos( 0, 0 )
DO CASE
CASE nMenuItem == 0
? "No selection met"
CASE nMenuItem == 1
QUIT
CASE nMenuItem == 2
? "continues program"
ENDCASE
ENDCASE
RETURN
