No line numbers when file is split into multiple windows
Post by Guest »
Is it possible to view line numbers when a file is open in two windows in Zeus? If so, how do I configure this? TIA.
Unfortunately there is no way to have line numbers in split view mode :(
A long time ago when the split view feature was first added, I remember there was some sort of problem with split views and line numbers. At the time the workaround to this problem was to disable line numbers in split mode.
So the bug you describe is in fact the work around that was added all those years ago :(
