Hope this the right forum.
Some time back Jussi helped with a script for deleting HTML tags. Worked fine.
Now have a problem removing the " character from a text file. Tried Sed and modifying the original script but could not get it to remove the offending ".
Eventually used the search and replace but it took 6 hours to find and replace 2500000 instances of " with a blank.
There must be a faster way.
This is to be done every month so any help in speeding it up would be appreciated.
Phil
Sed script help
Phil Hansen
Hi Phil,
For example, given this file data:
Running this sed command:
produces this result:
The s/\"/ /g command should work.Tried Sed and modifying the original script but could not get it to remove the offending "
This"is"a"test"string
This"is"a"test"stringCode: Select all
sed "s/\"/ /g" test.txtCode: Select all
This is a test string
This is a test string-
Phil Hansen
