when I open a project, is there the possibility to automatically open and edit all the files that were opened at the time project was closed? Also, when I close a project I would like to have all the opened files closed automatically, without selecting 'windows\close all' option. Is there any configuration trick to achieve this behaviour? Thanks in advance, Giorgio.
Beginner's question
Hi Giorgio,
Unfortunately there is no way to configure Zeus to do this at present
but I add this feature to the Zeus todo list.
Zeus does have a macro global string feature so it might also be possible to write a macro that does something like this. An example of how the macro global string works can be in the Slightly Extended Bookmarks posting.
Once again, unfortunately there is currently no way todo this
When I open a project, is there the possibility to automatically open and edit all the files that were opened at the time project was closed?
