tool:fgrep & code folding
raz
Post by raz »
I'm not sure if this is a bug or by design, but...
when I have code folded (hidden) and perform a tool / fgrep (find in files),
it does not find text that has been folded. This is not what I expect.
Details: C source code, example below
for example:
unfolded:
if (foobar)
<blah ...>
target text is here: HIT!
folded:
if (foobar)
If i use the tool/fgrep to search for "HIT" it will not 'find' it in 'folded' mode.
comments? thoughts? is this a bug, or by design?
-raz.
Post by Guest »
Hi Raz,
This is definitely a bug :)
As a test I used this bit of code:
int main()
  if (1)
    // find that
  if (1)
    // find this
  return test;
and folded up the two if nodes. Then when I run xfgrep -f -n this bug.cpp on the file the search result are as follows:
D:\temp\bug.cpp (10)     // find_this
But as you point out, when the enter key is used on this line of output the cursor ends up on line 14 (as shown in the status bar) and not on the line 10 displayed in the results window :(
I don't know if Zeus should open the fold in this case (my first impression would be to say that it should not), but it should definitely put the cursor on the folded line to indicate the text is located inside the fold.
I will add this to the bug list.
