Given a C# solution file, it is possible to ave Zeus run the build.
For example, assuming a MySolution.sln solution file, to setup Zeus to run the build do the following:
Step 1: Create the following build.cmd file to the Zeus install directory:
@echo off
rem
rem Usage: build.cmd MySolution.sln /build debug
rem
rem Name a file to capture the errors
set ErrorFile=BuildErrors.out
rem Delete the error file if it exists
if exist %ErrorFile% del %ErrorFile%
rem Run the build
rem %1 = Solution file
rem %2 = Build Action (i.e. /build /clean /rebuild)
rem %2 = Type of build (i.e. debug or release)
"d:\program files\Microsoft Visual Studio 8\Common7\IDE\devenv.exe" %1 %2 %3 /out %ErrorFile%
rem Display any errors produced
if exist %ErrorFile% type %ErrorFile%
if exist %ErrorFile% del %ErrorFile%- Make Command Line:"$zd\build.cmd" /build debug MySolution.sln
- Rebuild All Command Line:"$zd\build.cmd" /rebuild debug MySolution.sln
- Clean Command Line:"$zd\build.cmd" /clean debug MySolution.sln
