Hi Mark,
What happens if you take just the
scriptpy.dll from one of the earlier patches
Also note the
scriptpy.dll uses
python24.dll so either of these files might be the cause of the problem.
As a last resourt you could also just delete the
scriptpy.dll file and this will definitely remove the error
I am not really sure what has gone wrong since I would have thought the scriptpy.dll had not changed
